6 Speed shifter
6 Speed shifter
Hey I need some help----
My little wifey seems to have alot of problems with the console and the way DC has place the 6 speed shifter. The 5 speed used to be up away from the leg section of the seat. Has anyone tried putting a curve in the 6 speed shifter???? It seems that I could give her a little more room in the middle seat if it was curved upward about 3 inches. I am aware of the short shifter, I don't want a shorter shifter just up and away so that I'm not cracking her knees all the time.
Thanks for your help.
I bent mine about 6" closer. I also welded it solid on the bottom because it would twist the rubber damper on the bottom of the shaft when shifting. The shifter is designed to be straight.
Location: Dead Center in the Middle of TN. 20 miles from Jack Daniels, 10 miles from George Dickle and .8 mi from the liquor store at I-24 Exit 114
Here's a post by Vaugn Mackenzie and there were pictures in his file. Might see if this is still offered. jim
Vaughn MacKenzie
Senior Member
Member's Photo Gallery
My Classified Ads!
Heh. . . from an auto body shop in Kent, WA that makes them. I really like it, have had it since last September.
Jesse is the man! Costs 50 bucks + your old shift lever. Contact Info:
PRO FINISH
1506 S. CENTRAL AVE
KENT WA. 98032
(253)850-9422
Repair and Custom Paint (and Whiplash Shifter)
________________________________
Vaughn MacKenzie
Senior Member
My Classified Ads!
PRO FINISH
1506 S. CENTRAL AVE
KENT WA. 98032
(253)850-9422
commando
01-12-2011 09:27 PM
95black2615
10-08-2008 03:34 PM
