5th to 6th ever so slight grind
Old 01-13-2012 | 01:22 PM
narleycharlie's Avatar
Cool 5th to 6th ever so slight grind
Well the title bout explains my problem,very slight grind in my 05 2500 5.9 w/6spd stick.My buddy said it could be low on fluid , it has 125k on it now but there is no leakage anywhere on the tranny.Also I don t see a drain plug on the bottom of the tranny,so how would you change the oil in it?
The tranny is huge,don t look like something you want to remove in the driveway.Any insight on this would be greatly apprieciated. Charlie
Old 01-13-2012 | 02:03 PM
Totallyrad's Avatar
Have you ever serviced the tranny in 125k? I was looking for a little info for you but came up short. I use a Pennzoil synthetic in mine. IIRC the last time I got it from Advance Auto, about $42 for the entire change.
Old 01-13-2012 | 02:26 PM
Reelay's Avatar
I have a slight grind going into gear at certain rpms, but if you watch your tach and find the sweet spot where they don't grind use those rpms but I know it isn't always easy to do. I have changed my tranny oil out with amsoil recommended apps but still have the slight grind. Also have a new clutch which didn't do much for the slight grind. I believe there is a drain on the tranny somewhere can't remember just where but to fill it there is a big allen plug on the side and I pumped the fluid in. I overfilled to help with the grind situation which didn't help much I just think it is a minor glitch...
Old 01-14-2012 | 09:05 PM
Smile
My grind is at different rpm's. Being a manual tranny didn't know it needed serviceing like an auto.With 125k miles on it ,the grind only developed 3 or 4k ago.Guess I ll have to do more research.Thanks for the help. Charlie
Old 01-15-2012 | 02:56 AM
papaduck's Avatar
If reverse is to the right and up it is a NV5600. If it is to the left and down it is a G-56 and uses ATF+4 fluid.
I am assuming you have the NV5600. The fluid change on the NV-5600 was supossed to have been done at 30k miles. I have changed mine at every 30k, which may be overkill, but I want the tranny to last.
You will need to remove the power take off plate that is on the driver side of the tranny. Remove the magnet in the bottom of the tranny and clean it. Clean up the mounting surface of the plate and tranny and use RTV silicon to reinstall. If you want to over fill the tranny as many do, leave out a top bolt, fill from the normal fill hole until full. Install the plug and put an extra qt. of fluid in the top bolt hole. You must use a syncromesh fluid, I use Penzoil Syncromesh.
The fill plug is a 17mm allen. You can make a tool from a short 17mm headed hex bolt and weld the nut on the bolt and use a box wrench to remove and install the plug.
Old 01-15-2012 | 10:04 AM
Smile
Thanks Papa , I do have the NV5600.With no drain plug on the bottom how do you drain it ? By sipon ? Call me a dumbass for not reading the manual,got the truck 2 months after Katrina and had to go to work on houses.Since then hadn t thought of it .Thanks for the help.
Old 01-15-2012 | 11:48 AM
rebal's Avatar
pull one of the PTO cover bolts ..lowest one then remove the whole cover and clean it out and the magnet too
Old 01-15-2012 | 05:21 PM
papaduck's Avatar
rebal said it right. When the lower bolt is removed fluid will start to drain.
Once the cover is off there will only be a small amount of fluid in the tranny. I use a lint free cloth and clean the bottom of the tranny. An old 'T' shirt is lint free.
Old 01-16-2012 | 08:45 PM
Smile
Can t thank you guys enuff for your responses.Me personally,I don t know jack about these things,so it would be crazy for me to try to solve someone elses problems.All I can say is thank you very much. Charlie
Old 01-16-2012 | 09:36 PM
C Schomer's Avatar
I didn't have good luck with Amsoil as far as smooth shifting. RP synchromax has been great. RP box lubes are a little tough to find. I might try Pennzoil next time just to see if it's any cheaper and/or more available. I agree... put in 6 qts. I haven't seen ANY downside to that - leakage, higher temp or anything else. Craig
Old 01-16-2012 | 09:51 PM
Where do you find these different lubes,local parts houses?Heard of amsoil and thats the only one. Thanks Charlie
Old 01-17-2012 | 05:40 AM
papaduck's Avatar
Go to NAPA, AutoZone, O'Rielly's and any auto parts stores. I usually had to go to or 3 auto parts stores to get 6 qts. of Penzoil Syncromesh because they normally only have two or three in stock. I now start getting it bought ahead of time and stock up.
Old 01-18-2012 | 06:12 PM
C Schomer's Avatar
^^^ Same thing with RP (Royal Purple). Some napas, autozones and others sell it but might not have 6 qts. You could just have a napa store order 6 qts when you're ready and wait til they have the full order ready to pick up instead of running all over town. Craig
Old 01-19-2012 | 02:44 AM
Totallyrad's Avatar
If you need any other odds and ends Advance Auto has an on line deal right now, 15% off $100 order plus $50 off your next $100 order. Just They'll ship it to you or you can pick it up in store.
Reelay
10-12-2010 06:47 PM
sallyman1
01-27-2009 10:33 AM
Common
09-19-2006 05:27 PM
cowboy133
11-29-2005 05:59 PM
More Power
01-25-2004 06:44 PM
Quick Reply: 5th to 6th ever so slight grind
