5.9 want start
Old 12-22-2009 | 01:03 PM
mmppdavis's Avatar
5.9 want start
truck died the other day and thought it might be lift pump,checked out ok.batteries were a weak,tried charging them and it says their charged but if i let it sit a while they re weak again.i had troublr codes come up of p0148,p0111,p1755 and p 2509.i hooked some booster cables up to the truck and all the codes went away.I said all that to say this,is bad batteries a possibility of keeping it from cranking?I also changed the fuel filter.
Old 12-22-2009 | 01:38 PM
200cs's Avatar
Yes, bad batteries will cause all sorts of problems. Its a diesel, it needs lots of amps to turn it and build compression. Thats why it has two batteries. Replace them as a set.
Old 12-22-2009 | 02:16 PM
mmppdavis's Avatar
thanks for info
I HAD A FEELING AFTER I TRIED TO BOOST IT OFF AND IT WOULD THEN ACT LIKE IT WANTED TO CRANK BUT JUST DIDN'T HAVE ENOUGH POWER.TOOK ALL CABLES LOOSE AND SURE ENOUGH DRIVERS SIDE BATTERY IS DEAD AS A HAMMER
Old 12-22-2009 | 02:36 PM
dirtygoat's Avatar
Same thing happened to me the other day and the drivers side battery was dead, the other showed around 600 cca. I replaced both and I am good to go. Did you notice your interior cab lights also shutting off and any problems with the radio? My int cab lights would go off quickly after opening the door and my radio would not work a couple of times. I think this is the computer shutting off unnecesary load for the engine to keep on working.
Old 12-22-2009 | 03:44 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
Why is it that everyone thinks changing the fuel filter will make a truck start when it ran fine the day before but all of a sudden won't crank over like it did?
Old 12-22-2009 | 07:36 PM
mmppdavis's Avatar
Fuel Filter
HEY GUY ,I DIDN'T SAY THIS WAS THE ONLY REASON I CHANGED THE FILTER,IT WAS WELL PAST DUE.THOUGHT IT COULDN'T HURT
withalligators
10-08-2014 10:22 PM
2171CTD
02-20-2012 04:16 AM
CoolumConst
10-11-2008 10:00 PM
I PASS GAS
01-25-2006 07:51 PM
BigDan
31
01-22-2006 01:05 PM
Quick Reply: 5.9 want start
