4x4 owners please do this and post result
Old 09-30-2007 | 08:16 PM
rogerL1961's Avatar
Please get up under your truck go to the front drive line....put pressure on it in the middle and tell me if you feel any movement, try to move it back and forth. then post your result....
I have a small amount of movement in mine....
I am trying to locate a wa wa wa noise and I am wondering if this could be it.
Does anyone know what it looks like under the rubber boot? what kind of joint is it.....
Old 09-30-2007 | 08:53 PM
bob4x4's Avatar
There is some play in the slip splines.
Bob
Old 09-30-2007 | 11:55 PM
annabelle's Avatar
I have some play.
Old 10-01-2007 | 07:22 AM
paroxysym's Avatar
it should have some play. the wa wa wa sound would remind of the sound of an out of balance tire or something tire-related?
Old 10-01-2007 | 08:29 AM
Jetx4's Avatar
Small amount of play on mine
Old 10-01-2007 | 11:58 AM
irocin350's Avatar
hey i have same sound ,its between 60 - 80 hmm i thought i was crazy
Old 10-01-2007 | 12:36 PM
mrblond's Avatar
this wa wa sound is at speed consistant or only when the front suspension drops an inch, 1/2 second at a time say for road variations? Hence the wa wa insted if just waaaaaaaa
You could adjust caster and see if the noise go's away?
Old 10-01-2007 | 12:38 PM
Little-bit's Avatar
I heard the wa wa wa "road noise" last year. The u-joint closest to the transfer case on the front drive shaft went out. It split my transfer case completly in half. Not a good thing when your 250 miles from home and pulling a loaded trailer. It cost me $1500 for the repair.
Old 10-03-2007 | 04:16 PM
Southern Pride's Avatar
i have minimal slack as well. my front u-joint was goin out last november, and made a constant vibrating sound at between 60 and 70 mph, it was holding on what seemed to be the hardened mud around it LOL. it was a close one.
Old 10-03-2007 | 11:07 PM
rogerL1961's Avatar
I am not feeling any movement on the ujoints there...any way to test them other than wiggling them???
MX429
44
02-16-2008 08:35 AM
V.R.Wheeler
08-04-2007 01:00 PM
Mike D
26
02-19-2007 08:43 AM
Mike D
02-16-2004 12:57 PM
Quick Reply: 4x4 owners please do this and post result
