48RE Band Adjusting Screw Pictures
Hi guys, got Front Band and Rear Band Adjustment info from the Forum but not sure where are those adjusting screws. Any pictures ????
I was wondering on that also. I have tried searching, but Tapatalk doesn't have the best search feature, it kind of sucks for searching, but it does rock for convenience. Anyways, I thought I remember seeing it here before.
Front band is outside the case above the shifter lever. 2 turns out from 72 inch pounds.
NO, NO, NO!!!!!! wrong specs. 1 3/4 turn out form 72 inch lbs set on the torx screw. 2 turns will be too much on a used band and slip it even more. May have to go down to 1 1/2 turns if the band is stretched too much.
johnny7
19
12-22-2012 01:45 PM
