40'' Nelson ?
Old 01-27-2007 | 09:03 AM
PZM123's Avatar
40'' Nelson ?
Found a part # [NEL86544M] 4'' in & out with a 10'' body. Is it straight through & how long is it ? Seen someone running a 40'' with the cat. This is what I want to try. Stock motor so I think the 51'' 5'' in & out would be a waste. Thoughts please.
Old 01-27-2007 | 09:52 AM
TurboTed's Avatar
The part # for the 40" is 86127M. It is a smaller diameter. Either 7 or8"(I forget! ) It sounds basically the same with the cat, as the 51" without. Perhaps a shade louder when you really step on it, but otherwise the same. Hope this helps!
Old 01-27-2007 | 11:42 AM
PZM123's Avatar
Well thanks, BUT I can't find a match for 86127M on the Ryder page.
Old 01-27-2007 | 03:38 PM
TurboTed's Avatar
I bought it at Cummins Alberta. They brought it in on their Fleetguard order. If you have a Cummins dealer near you, you can order it there.
Old 01-27-2007 | 06:30 PM
TurboTed's Avatar
That number is "up to date", as I just had it installed last month.
Old 01-27-2007 | 09:23 PM
j2mk's Avatar
The Donaldson M085171 is also a 40" straight thru 4" muffler with a 8.5 inch diameter. Ryder has it for 58.60 special order. Mine was delivered in less than a week.
Old 01-29-2007 | 08:47 AM
Fisherguy's Avatar
You show a 51" in your gallery, did you change it to a 40"?
If so, how come?
Old 01-29-2007 | 10:55 AM
TurboTed's Avatar
If so, how come?
The 51" was on the 03, which did not have a cat. The 40" is on the 05. which does have a cat.
Old 01-29-2007 | 01:03 PM
Fisherguy's Avatar
Which do you like better TT?
Old 01-29-2007 | 01:14 PM
GreyTD's Avatar
Turboted did the hangers come with the muffler or did you make your own?
Old 01-29-2007 | 02:29 PM
TurboTed's Avatar
They sound about the same, because the 05 has the cat. The 40" is a bit louder under heavy acceleration, but not an unbearable drone type sound. I had it installed at a muffler shop, and they weld the hangers on.
draebi
166
05-03-2006 12:05 PM
jflan27
02-09-2005 06:59 AM
kelley15
01-16-2005 10:03 AM
HorseHauler
10-06-2004 01:36 AM
SoCal-305
08-17-2004 06:05 PM
Quick Reply: 40'' Nelson ?
