3rd gen tranny question .
Old 06-13-2011 | 10:42 PM
John Taylor's Avatar
Quick question for the group . It's time to change the fluids and filter , in my transmission , 2004.5 48RE . I tow a 5th wheel with . Take it too a shop or just change the fluid and filter ? I have the transmission service before . I just don't have a faith in the local tranny shops . What do you guys think , good or bad !
Is there anything that I should be worried about ?
Old 06-17-2011 | 10:34 PM
TexasCTD's Avatar
It's easy to do, just messy.......if you still have the stock tranny pan.
You might consider upgrading to a Mag Hytec double deep pan when you do the service, if you decide to do it.
Just drop the pan and discard the fluid. (if you have a DD pan, it will have a drain plug making this much easier). Change out the filter. Replace the pan and refill. It's very easy. It doesn't get all the fluid out but it gets enough. My 30 year transmission man recommends what Im doing, and it seems to work so far....152K on mine so far...but it was built with DTT parts at 88K just because I wanted to upgrade for more power.
I've change mine out pretty religiously about every 20K miles but thinking of extending it to 25K.
Old 06-17-2011 | 10:35 PM
TexasCTD's Avatar
Oh, you will need a torx head screw driver for the 2 filter screws.
Old 06-17-2011 | 11:24 PM
annabelle's Avatar
# 25 Torx head. Might just a drain plug into your stock pan.
anonymous_1
13
04-30-2020 04:29 PM
BRUISER
02-02-2015 11:25 AM
12ValverDave
16
05-05-2009 09:31 PM
1qckdodge
03-05-2007 09:53 AM
RLS
12-10-2002 12:38 PM
Quick Reply: 3rd gen tranny question .
