36,000mi Service & Need Intake
...dealer wants me to spend $500 on oil, trans, axles etc at the 36,000 service next weekend. Oh, and I think its about time for a new intake. My stock filter is about there.
Any suggestions in your experience on what should really be done at 36K and which intake I should go with? I don't tow much with my truck; my boat a few times/year and building supplies once in a while. I may be doing lots of highway driving next Fall... like 300mi/day or more (maybe a Smarty for MPG would be a good investment).
thanks for any input,
-daniel
-daniel
-daniel
-daniel
Mike
I am with the others. Do it yourself and save a bunch of money.
Oil change is straight forward, just buy a fleetguard stratapore filter and your choice of 15w40 diesel truck rated oil. Personally I use Shell Rotella T bought at Walmart. Filter can be purchased at Cummins or online at Geno's Garage.
Drop your transmission pan and drain the fluid. Replace the Trans filter which will be visible when the pan is off. Replace the pan and refill with ATF +4 trans fluid. I get the fluid and filter for this at the local dealer.
Drain the transfer case from the lower bolt, replace the bolt. Refill through the top bolt with ATF +4.
Remove the front and rear Differential covers and let the fluid drain out. Spray around with brake parts cleaner. Replace covers and then refill with your choice of 75w90 or 75w140 synthetic GL5 Rated Gear Oil. Personally, I use Mobil 1 75w90.
The dealers want way to much for this simple stuff. Also, I don't want them tinkering on it. I am afraid they will make a careless mistake. They don't love your truck like you do. To them it is just a hunk of steel for them to make money on.
Once you do all this stuff once, it is easy. Just go slow, take your time, buy everything you need before you start each job.....and then the next time it will be easy.
Alright, I'm considering it. Its not that I don't think I can do it, its just a matter of finding the time to do it. Like you guys, I'd rather work on my own truck than let someone else, even though I do have a good dealer that I trust. Hmmm? Will I need any special tools...I'm just working with a pretty standard residential 2-car garage here
-daniel
-daniel
It will help if you have a cap wrench to go on the end of your oil filter to get it from the bottom with a ratchet and extensions. Also, a large freezer bag to catch the filter in will help avoid a mess.
You need a 1 1/8'' socket to remove the cap on the fuel filter housing to access the fuel filter.
Remember that your truck holds 3 gallons of oil, so at least a 15 quart oil pan is a must. After draining, just take it to autozone etc. and drain it in their oil recycle bin.
5 Gallon bucket
A cap filter wrench only works if you use the filters with flutes.. I use the LF3894 Stratopore. Identical to the fluted filter, but cheaper. I use a KD band wrench with a 3/8s extension. Incidently, don't be fooled when you look at your engine drain plug and think it takes some kind of special tool. It's just a 3/8s square drive. Use a ratchet and a short extension. Easy job. Fuel filter is the easiest change I've ever done. A snap. DON'T buy your filters from Dodge. 3Xs the Cummins price.
Originally Posted by jwooden
FYI: A 5-gallon bucket fits perfectly under my oil pan (stock tires, no lift, 4X4).
That is an excellent idea. I never really thought about the good ole 5 gallon bucket. Probably would also help reduce any side spray from wind etc. Thanks.
roughstock
02-10-2014 09:36 PM
Taquache
21
06-24-2012 03:11 PM
BA05'CTD
01-07-2007 03:08 PM
