Is 3 cylinders warm up option enabled on 3rd gen ?
I am starting to wonder about it.
My truck, if started and left unattended it will raise idle to 1000rpm (as supposed to) if temp is around 30s, then after few seconds, approx 20 or 30 idle will become different, a little rougher, and sound like looping a little, but not quite like a 3 cylinder shut down, which many swears it has been eliminated on 3rd gen trucks.
What this could be ? Injector timing changed by ECM to aid warmup ? INjection eventes modified to aid warmup ?
It is definitely a different idle pattern that I don't encounter any other time.
PS My truck runs great, excellent mileage and power and injectors have been tested twice by different dealers with no issues.
The CR's don't do a 3 cylinder high idle. From the scope readings I have seen it does split the main event in 2 when it goes into the high idle at low intake air temp.
That could be what is causing the rough idle if your injectors are not balanced or possibly carboned. Mine is dead smooth on the auto high idle and the idle up feature all the way to 1500 rpms. I would suspect a slight imbalance is causing the roughness.
Jim O
Nope, what you were hearing is just cold cylinders and the ECU adjusting the timing/injection. A cold start will make all kinds of noise and weird idling on any of these engines. Even the 12V's lope like crazy on a cold start.
It has to be a change in timing or injection events since it doesn't do it if I hold it at 1000 rpm manually.
Here's a video of the sound
http://www.youtube.com/watch?v=DfNMgLNTqzA
Mine does it too, I don't worry about it though. It is most likely just the computer changing things up, and they probably don't do it on the newer ones when the high idle is manually engaged because that is telling the computer you are using a pto and thats why it ramps it up. So since it thinks you are using a pto it wont change any settings that might mess with the engine speed while running that pto.
