2wd balljoints?
Old 11-04-2009 | 04:28 PM
bowedup2003's Avatar
2wd balljoints?
Quick question guys, are the lower ball joints on the 2wd 3500's pressed or riveted in? I have 1 going out, the one I bought from oriellys is a press-in but the local frontend shop says they are riveted in
I plan on tackling this Saturday and I want go make sure I have the right parts.
Thanks,
Bowedup
Old 11-04-2009 | 05:08 PM
MikeyB's Avatar
Should be pressed in.
MikeyB
Old 11-04-2009 | 08:04 PM
8mpg's Avatar
My 06 is riveted
Old 11-04-2009 | 08:40 PM
Ok, so the 2003's are pressed in and the 2006's are riveted in...
Any idea when they made the changeover? My 2004.5 falls right in the middle!
Thanks,
Bowedup
Old 11-05-2009 | 04:38 PM
Anybody know where the break is between pressed and riveted balljoints?
Thanks,
Bowedup
Old 11-08-2009 | 06:44 AM
Ok, in case anyone else gets to do there's, my 2004.5 had pressed-in balljoints and the loaner tools from oriellys will not work w/o some grinding and modifying to the press cups.
Bowedup
Old 11-20-2009 | 05:47 PM
thunderdawg's Avatar
Thanks for the follow up.
Old 11-21-2009 | 05:57 PM
Hannibal's Avatar
I just replaced the lowers on my '05 2wd 2500 today. They're pressed in and boy are they tight. The loaner tool kit from Advance Auto Parts worked great but a longer breaker bar or cheater would have made it a lot easier. I "think" they're all pressed into a thick plate that's riveted to the lower control arm. Some replacements are already pressed into the plate and you replace the plate along with the joint. Moogs are press in so no grinding the rivets out. With 118k miles on 'em, mine had a good 1/4" vertical play in them and the original grease is all dried out. Looks like the upper control arms will be easy in comparison... Joints aren't bad but the boots are crumbling at only 5yrs.
Old 11-22-2009 | 07:36 PM
w.tx iceman's Avatar
What brand of ball joints did you go with, greasable?
Old 11-23-2009 | 06:33 AM
Hannibal's Avatar
I went with Moog. They're greasable. In the pic is the tool and the spindle tied back with the caliper tied back the other way. Now that it's done it wasn't all that bad but in the process I had my doubts. Next time I will without doubt have a longer breaker bar. Here's the part numbers on Moog's page...
http://www.moog-suspension-parts.com....asp?cat=12638
txarrowhunter
07-06-2010 05:03 PM
Fishbait
11-17-2004 12:07 PM
hellotbone
19
05-27-2003 10:30 AM
hellotbone
04-30-2003 11:41 AM
AlpineRAM
0
12-26-2002 09:03 AM
Quick Reply: 2wd balljoints?
