2500 RPM's and Thats It!
Old 12-10-2007 | 07:41 AM
spye's Avatar
Well I posted sometime back that my 04.5 had thrown some codes and acted up a little. Well it has been running fine since so I have not payed that much attention to it. The only thing I have noticed is that at idle it will act like it surges or misses a beat. I have attributed this to the ac compressor but?
Now I get in it this morning and it will only rev to around 2500rpms, I noticed it while getting out on freeway in 3rd, nailed it (to the floor) and it revved and pulled good until 2500 and then just fell flat on its face. Now it held the rpm level but it was acting almost like it was missing. The truck runs fine and strong until 2500ish where it just wont go any further in revs. I can rev it beyond when it is not under load. What could this be? APPS, FCA sticking, ???. I am at a loss here, I have included all specifics that I can about the codes that were thrown about a month ago, and specifics about truck. Any help is appreciated.
Codes:
P0652-Low voltage at the #1 sensor supply circuit
P2121-Pedal position sensor 1
P0193-Fuel Rail Pressure high
P0341-Cam Position sensor 1
Truck is 04.5 with 600 Cummins, 6 spd, no mods other than K&N and exhaust
Old 12-10-2007 | 08:11 AM
John Faughn's Avatar
You need to address the low voltage to sensors 1st , then clear all other codes , with low voltage , you get all kinds of things reacting badly to low volts .
With that fixed the others may not be a problem .
Old 12-10-2007 | 12:00 PM
Spooler's Avatar
Read this. I beat this is your problem.....
https://www.dieseltruckresource.com/...ad.php?t=81936
A wirerubbed raw in a loom around oil filter. Read Thread.
Old 12-10-2007 | 12:21 PM
spye's Avatar
Spooler,
Thanks for the link, I am going to check this out this evening and see if this could be it. Sure sounds like it might be the problem.
Old 12-10-2007 | 06:28 PM
spye's Avatar
BINGO!!!
I got under truck this evening and checked the wires and there it was. The wires had been rubbing on the compressor and had rubbed through the covering. Fixed it up, drove it and it is better than ever. Thanks for the help guys, this is why I look this thread over and ask for help when needed.
Spye
Old 12-10-2007 | 10:27 PM
Spooler's Avatar
Glad it helped you out...... Easy fix.....
checkster
02-17-2009 10:53 AM
thinkindodge
09-13-2007 09:31 PM
skeeter
01-18-2006 03:17 PM
fishin fever
02-22-2004 08:32 PM
FMF MX
12-03-2003 11:30 AM
Quick Reply: 2500 RPM's and Thats It!
