21,000 mile service
21,000 mile service
This weekend, changed the fuel filter (looked good), changed the oil, inspected the pto covers on the trans....weaping, inspected rear diff seal....weaping, inspected air filter....dirty, cleaned the anti-freeze from the top block pugs and tightened....still not leaking, valve cover... weaping oil, check block heater cover... not leaking.....I got all of these straightened out. With many interuptions (wife), I forgot to check the reverse light and also forgot to plug back up the IAT. BINGO... ...code 107 and 73...oops.
still love the truck
JKE
JKE
loose. with a new motor or truck, it is a good idea to sniff around it real good after a few miles to check for things that have worked loose or loose from the very start. I am satisfied with everything at this point. I still need to fix the reverse light. I will check for loose bolts etc again in a few thousand miles.
Happy trucking....JKE
kenni
62
03-11-2012 08:46 AM
finndogg54
21
08-20-2007 07:01 PM
SOhappy
34
03-04-2006 04:16 AM
