2006 High Idle - Manual Trans?
I've got a 2006 with a manual trans and want to be able to use the high idle feature. I grounded the ecm pin 22 (rear connector) and used my triple dog to enable the idle up feature. It doesn't work. I turn the cruise on and hit the set button and nothing happens. Tried accel and decel buttons and nothing. Any ideas??
In Neutral, parking brake on, clutch not depressed?
If you're doing all that it should work.
I had mine enabled at a dealer the first time, then lost it went my Bullydog went nuts and had to restore the ECM back to stock and re-load a tune, but I just re-enabled it with the Bullydog.
I dunno???
I dunno???
Rollin'_Coal
27
12-17-2012 08:07 PM
derkol
12-07-2010 01:18 PM
jmccart
06-12-2007 02:12 PM
STATELINE
42
11-25-2005 05:05 PM
