2006 - G56 Transmission Fluid Change
Old 09-23-2009 | 08:05 PM
carl48's Avatar
if you tow go with synthetic
Old 09-24-2009 | 09:54 AM
D-Roc's Avatar
I just changed out my trany and tcase with ATF+4...from using Royal Purple Synchromax.
All I can say, is that I'm dumping the ATF+4 with only 6000 miles on it and going back to RPS!
Old 09-24-2009 | 11:16 AM
Grit Dog's Avatar
Easiest way I found to re-fill teh trans and t case (t case especially) is to get a little drill operated pump and fittings for a couple pieces of hose. use the pump to fill them from a gallon jug. Otherwise it's a buch of contortions with a hose tped to the end of a gear oil cap.
Old 09-24-2009 | 12:13 PM
jwhip's Avatar
Yesterday, I just finished changing the oil in the front differential, rear differential, transfer case and the transmission along with the transmission filter. I have a 2005 the 48RE transmission. What a royal pain in the butt! Since I had no drain plug, transmission fluid went everywhere! I put a plug in so that I would never have to do that again.
As far as ATF+4 fluid, I went to NAPA and paid $3.88/qt for the NAPA brand which is made by valvoline which is over $5. It took 7 quarts to refill it to the max hot level on the dipstick.
NickBeek
13
07-29-2008 09:16 PM
CalypsoCowboy
24
05-18-2008 09:04 PM
SundayMoney
02-20-2008 12:20 PM
gnuesse
04-16-2007 07:10 AM
gnuesse
03-18-2006 04:44 PM
Quick Reply: 2006 - G56 Transmission Fluid Change
