2006 Braking problem
Old 10-03-2009 | 08:12 AM
BonesinWY's Avatar
Last winter, I was screwing around on the ice a little. I was in reverse, backing up, hit the brakes hard. Ever since then, my brakes don't work right. The brake pedal is somewhat hard and the truck does not have near the stopping power it had. You don't notice it as much just putting around, but really notice it traveling 40mph and stopping at a light. I took it to the dealer, and of course they could find nothing wrong. After looking at the rotors, I would almost have to think the rear brakes are working and the front are not? It is really noticable with a trailer on. The brake pedal is not rock hard, but way harder than it was. Any ideas? Any ideas on how to troubleshoot this? Truck is 2006 automatic. Thanks!
Old 10-03-2009 | 09:19 AM
rich's Avatar
is there a proportion vave on these trucks that seperate where the brake power goes maybe its bad?
Old 10-03-2009 | 10:37 AM
BonesinWY's Avatar
Thats another thing I was wondering. I don't think it is a vacuum problem as the cruise control still works fine. The pedal doesn't go spongy like there is air in the system either.
Old 10-03-2009 | 11:02 AM
06RAM2500's Avatar
I'm having the same problem. I flushed the brakes and my brakes worked again. Now it's the same issue, no front or rear brakes. Going to flush them again and see what's up.
Old 10-03-2009 | 11:40 AM
rich's Avatar
these brakes run off the power steeringpump. hydroboost set up
Old 10-04-2009 | 06:45 PM
BonesinWY's Avatar
Anyone?
Old 10-15-2009 | 08:45 AM
RADICALRAY's Avatar
maybe your power steering pump is going bad,or low on fluid.
i have a break problem to ,not bad but there should be more. I can feel my power steering pump ratling when you turn the steering wheel back and forth. i bought a new pump just havn`t had time to change it. hope it helps with my breaks. I`ll let ya know if it does.
efi900cat
11-09-2007 10:10 PM
smknram
02-15-2007 10:21 AM
lcdo7495
03-11-2006 10:08 AM
Txwelder
03-27-2004 09:16 PM
03quadduallyho
03-24-2003 05:34 PM
Quick Reply: 2006 Braking problem
