2005 5.9 Transmission Question.
We have owned our truck since new and now have just over 190,000 miles on the transmission and power train with no issues. Recently we have noticed when the truck sits after a couple days, when shifting into reverse or drive there is a delayed engagement of movement. Is it time to rebuild? Replace the torque converter? Also, would service of the wheel bearing and u-joints be advisable? If trans rebuild, recommended components other than Dodge. Been a great truck and still looks new. We live near Charlotte,N.C.
Thanks,
Thanks,
Thanks,
Thanks,
Sounds like the check valve not holding fluid up in the TC, a quick way to check is to try this on your first startup, immediately put it in neutral, wait about 5-10 seconds then see fi drive or reverse engage immediately.
If so, nothing to worry about, they will all to it after a while, not worth getting fixed IMHO.
You could have it fixed as well.
KevinT
03-12-2014 10:02 AM
BCarmicle
09-14-2005 07:27 PM
