2005 5.9 idle surge.
Guys, I have a huge issue with my truck. I bought it used with 200k, since I’ve had it, it lopes at idle, and when you rev it up, it stays reved up and surges. Sometimes even climbing to where I need to shut it off to stop it. I have changed just about everything except the high pressure pump and common rail, including injectors and throttle pedal. No codes present. I can unplug the map sensor and it stops but no power. Could this be a CPU or wiring problem? This has stumped several dodge diesel mechanics.
Back to morning brew . . .
