2005 48re
#31
The six speed is the best for towing hands down.Any auto is a compromise,but towing abt 7 to 9 k I have no serious complaints with the 48re . I haul up fancy gap and black mtn. and monteagle a good bit and I assure you i never let off the pedal. I'm not sure why you would, unless the curves were only possible at 50. I hit the bottom of fancy gap at 70mph ,its 8 miles to the top ,about 3 miles into the hill the tranny shifts from 4th to 3rd and holds it to the top ,running abt 60 mph.I haven't climbed any hills that I needed to let up on the pedal to the point the tranny would shift into od,but there's a lot of hills I haven't climbed,most hills are pulled in 4th with a shift down into 3rd and back into 4th at the top.,but I'm only pulling moderate loads,might be a whole different ball-game with max gvw. If I ever need to tow 15k on a daily basis .it will be with a medium duty truck and a stick shift.
#33
my 05 48re drove me nuts with the back and forth shifting from 3rd to 4th when we where going up to alpine arizona with the switchbacks and sharp curves and up and downs pulling 12000lbs trying to maintain 40-45mph. it got so bad i just slowed down to 35mph and ran it in 2nd until i got on some strait road
#34
Re: Hey HammaJamma
Originally posted by DanTana
I am in the process of buying a 10k 5er. I travel the same hills you do. I'll see how my 4.10s like Fancy Gap.
#36
Again guys , it depends on your load and the road. The 2005 has lots of power and will pull a good load up a good hill in 4th . but when you hit that ballance where it starts to hunt gears you gotta be able to lockout 4th and make it stay in 3rd.
#38
UPDATE,,,,,,,,,
Originally posted by RATTLINRAM
Well I hope that there turns out to be a fix for this. My Dad just ordered a 2005 with the 48re to replace his current (trouble-free) 2000 V-10 Ram with the 47re. He has been used to how that performed when towing their 9000+lb. 5er. The folks are planning another trip from VA to CA and up through the Rockies again next year, which is one of the reasons for the new truck. My 5er is identical to his except about 800-1000lbs heavier becuase of the double slides. My 99 with the mods is about the same HP and TQ ratings as the new trucks and I don't think I would care for the 05 tranny and not being able to completely lock-out OD.
This is the first I had read of this change and I hope I haven't steered Dad wrong in his decision.
Dad has not stopped talking about how well the new truck performed. I never thought I would ever hear my 76 year old father use the phrase,,,, "That new transmission and diesel engine is just AWSOME!" I had told him of all the info that I had read about concerning the differences in this trans and the 47RE he had in the V-10. He said he quickly learned the right "touch" on the throttle for the various situations and he was very impressed with the performance. No gear hunting and good hold back on the down grades.
BCarmicle
09-14-2005 07:27 PM
bigman
07-25-2005 07:44 AM
