2003 wont start when cold
Old 02-21-2009 | 06:11 AM
Hounddog's Avatar
Hey SPPOLER any TESTS for the WIF LIGHT WARNING and any breakdown on how its SUPPOSE to work? After all this time,since 03 you'd think someone would have shhoved this WIF light into a Chrysler reps face when quoted THOUSANDS to repair a system that has a WARNING device that KNOWN seem to operate as designed. WIF light worked on my 1993 W250 great.If it came on there was WATER in the filter bowl.
Old 02-21-2009 | 08:41 PM
Spooler's Avatar
You would think so. I would need to get ahold of a shop manual to take a look at the testing procedure. If it happend to me I WOULD have it in there face for sure. They wouldn't like me very much when I got done with'em.
As far as the crapy A/C issues we have, there is a reason for that also. Since mine started acting stupid again last summer and working with it before the issue is the ECM fan clutch programming needs to be fixed. They are not turning the fan on quick enough at startup and at high ambient temps. I noticed this when I was looking at my truck way back when. I will evacuate and recharge my system this summer when it gets hot. I am then going to stick an electric fan on the condenser. Last summer I could make mine act stupid at will. It would do it everytime on initial startup on a very hot/humid day. The high side pressure is spiking up to 450 to 500 psi due to no airflow over the condensor and it ends up pushing the refrigerent out the seals. Which seals? I don't know or care. The root cause is no airflow over the condenser at slow speeds or on initial startup. As you know it will take over a year to see if it fixes the issue cause you can normaly make it through one summer with no issues. It's the second summer when I started having issues again. That's why at the first of every summer you have to recharge the darn A/C system again.
Yeah, I am still mad about the A/C. It hot down here.....LOL
Old 02-22-2009 | 10:25 PM
hot shot's Avatar
same prob.when trying to start.even plugged in i sometimes have to take out fuel filter to get started.new lift pump didnt fix problem.found a place in st.louis that rebuilds inj. for cummins for 208.00 per inj.with a core.going to try to change them myself instead of paying dodge and cummins this time.any advice from anyone would be app.
Old 02-23-2009 | 12:40 AM
Hounddog's Avatar
I've read many times that removing them is no issue.Its reinstalling them that get screwed up.If not installed correctly it mimics same issue you have.
Old 02-23-2009 | 09:53 AM
curts99's Avatar
hound dog here you go
1 drain the waterin fuel seperator
2 with scanner turn out check engine light
3 cycle ignition switch to on to off to on
4 with scanner read dtc's did p2269 return
yes see ctd p0169 wif light on too long under diagnostic tests
no go to step 2
1 disconnect wif snsor harness connector monitor scanner while jumping siginal circuit of the wif sensor and battery (+)
2 did wif light go out
yes test complete
no replace ecm
Old 02-23-2009 | 09:54 AM
curts99's Avatar
there are 4 more test for the wif snsr
Old 02-24-2009 | 08:13 PM
titan1's Avatar
I would like the contact info for this guy........I am leaning toward injector/s on mine as well.
Will not start cold or warm unless the engine cranks very fast......usually with the help of a battery charger for 20minutes
Old 02-24-2009 | 11:10 PM
Hounddog's Avatar
Wonder why NO ONE ever reports seeing that light come on.I have NEVER read a post on ANY Dodge truck forum about a 3rd gen WIF light being activated because of WIF.Yet MANY posts about water in fuel damage.I had MANY 1st and 2nd Gen trucks come into the shop with the WIF light on and water really was in the fuel.I've had it come on after a fillup on my 1st gen and had to stop and drain it.Worked as designed.But NOT a 3rd Gen.
Old 02-25-2009 | 09:48 AM
Jeff in TD's Avatar
Now that you mention it, I think the only threads I've seen about a 3rd gen WIF light come on is after someone has washed the engine and gotten water in the plug.
I was thinking of adding a 2 micron filter (these injector threads kind of spook me), and keeping the stock canister as a prefilter, to keep the fuel heater, and as the water trap...
I wonder if it would be better to add a seperate water catcher...
Old 02-25-2009 | 01:37 PM
Ace's Avatar
Ace
That's exactly what I did. Another one of my useless filters:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_10.JPG
Old 02-25-2009 | 02:07 PM
Jeff in TD's Avatar
Not to hyjack the thread too bad, but that looks great.
I take it you built it yourself? Could you post details about what parts, how much you spent, and how it's built?
Old 02-25-2009 | 06:55 PM
Ace's Avatar
Ace
Sure, here's the thread with a writeup I did on it about a month ago:
https://www.dieseltruckresource.com/...d.php?t=231582
Old 02-25-2009 | 09:26 PM
rjsram's Avatar
mine was the same way the reason, 5 bad injectors warrenty covered it and alls fine untill now
carkon
05-23-2010 07:22 AM
jetbt25
25
03-16-2009 09:05 PM
qcstunter
01-09-2007 04:10 PM
joeel
12-06-2006 09:22 PM
fishingfool27
08-01-2005 02:10 PM
Quick Reply: 2003 wont start when cold
