2003 hesitation after a long light DESPERATE
Old 07-25-2010 | 05:48 PM
w63's Avatar
w63
I,m ready to buy a ford This is my new used motor. After installation I installed a 3 micron filtre and 5 psi warning light on my fuel system than I noticed my light was flickering under load.It was dropping to 5 psi under load .so I installed a on the frame fuel pump from BD Power. Pulled the one in tank . Lots of pressure now No more red warning light New problem while sitting at a long red light when I take off it seems like it starving for fuel for a couple seconds. Short stops it,s fine I,m going on holidays fri so I,m very desperate ANY HELP WOULD BE GREAT THis also happened briefly before the new pump I believe it,s getting worse.
Old 07-25-2010 | 07:23 PM
Blueboy's Avatar
Did you check your fuel filter.
Old 07-25-2010 | 09:23 PM
w63's Avatar
w63
N o I just put this in last week I just took it for a drive and noticed that when idling if I rev it up it shoots a little smoke out almost looks dark not white??
abc4yew
03-22-2015 03:52 PM
blackdually6
12-03-2007 07:04 PM
thumper 549
01-23-2005 02:47 PM
thumper 549
01-01-2005 04:09 PM
dodgediesel4x4
12-01-2004 03:45 PM
Quick Reply: 2003 hesitation after a long light DESPERATE
