2003 fuel pump code p0628
Old 12-06-2012 | 12:06 PM
jivemother's Avatar
Exclamation 2003 fuel pump code p0628
got an 2003 2500 4x4 190,000 miles tuck as has staled a few times at stop sighns and going down the road . fresh oil and fuel filter [1000 miles on them ] pulled codes got a p0628 low voltage at fuel lift pump . any ideas ? fuel pump going bad ? relay ? electrical ?
Old 12-06-2012 | 01:09 PM
jivemother's Avatar
is it in the tank ? or on frame?
Old 12-06-2012 | 08:50 PM
forwardho's Avatar
I would say you have a bad lift pump. I have had to replace my lift pump twice in 75000 miles.I had the same code. My pump was and still is on the filter.
Old 12-07-2012 | 07:27 AM
jivemother's Avatar
oh up on filter on motor ?
Old 12-07-2012 | 09:19 AM
lcmedic's Avatar
My code info shows fuel pump relay circuit malf. Try swapping relay w/ one that isnt currently being used
Old 12-07-2012 | 03:34 PM
jivemother's Avatar
were is the relay under hood in fues box or somewere else
Old 12-07-2012 | 04:31 PM
Spooler's Avatar
99% of the time when you get this code you have a bad LP.
Old 12-07-2012 | 04:37 PM
jivemother's Avatar
well just seeing if there is anything stupid to look for
Old 12-07-2012 | 05:17 PM
lcmedic's Avatar
Relay in box under hood "fuel system relay". Also ck ALL ground points. I agree w/ spooler but it dont hurt to ck.
Raspy
12-22-2016 06:34 PM
Marcus
05-03-2010 07:29 PM
Harley1
11-25-2009 06:40 AM
ctd4stan
03-19-2009 08:35 PM
Quick Reply: 2003 fuel pump code p0628
