2003 auto trans acting funny
I just bought a 2003 dodge ram 3500 with 5.9 cummins and auto trans its the 48re runs and drive fine but at the stop light it feals like the truck is trying to push me on its own and when i take my foot off the brake it goe son its own for a second then it feals liek the pressue goes away and it just coast until i step on the pedal and it shift REALLy hard going from park to drive or neutral to rev,park,drive like it has alot of pressure build up inthe trans i tookit to the local tranny shop they hooked their computer on it and we did a road test with it hooked up and no codes popped up or anything funny showed up on his computer but ther is obviously a problem where do i start do i take it and have it serviced and bands adjusted?? sound like maybe a pressure switch???? also while at the stop light i tried to rev up the gas with my foot on the brake and it didnt do nodda is this a factory saftey thing some peope dont try and power brake or is there yet another problem i need to look into ???
Maybe someone has put the wrong type of trans fluid in. ATF4 is what it should have. I would get the fluid changed and filter to start. You should also check the u joints on the drive shaft that can give a hard noise shifting from park to drive. How many miles are on it.
Sound like there may be a an issue in the valve body. Mine have always felt like they kind of want to push you at a stoplight.
When they did the road test with you, did they check the line pressure on the trans? Just driving around looking for codes isn't gonna cut it. Need to see if it has some kind of internal pressure leak, something like that.
Also, if the transmission filter is plugged up it will act really weird as well. Might check that as well.
I took the truck into dealership today ( I KNOW I KNOW) they trans guy seemed to think it was the torque converter hes going to look it over run some test and do and inpsection to find out what the problem is i hope its something simple and alot whole lot cheaper than rebuilding the trans
Anybody with any ideas a few trans shops i talked to say i need a torque converter but i think its just a big ticket item they can get me for then say oh this is bad too after after i soend the money ont he torque converti i might not need??? couldnt it be the Overdrive/Lock-up Solenoid Group with Electric Governor ????? or one of the other may noids in side?? even with no codes pulled i find it hard to belive its actually the covnerter the truck doesnt even have a 5th wheel or goose neck in it and never has??
New filter and flush before you spend any more money.(if you have not done this already) Do you have a diesel shop anywhere nearby? You may find a guy in a performance diesel shop who knows a helluva lot more about your tranny than anybody at the ***********. I know 3 of our trucks(04.5 and two 05's) that have in excess of 250,000 miles on the original 48re's. So even if the tq and vb have been replaced that does'nt always mean it's been rebuilt. Does yours have a 47 or 48?
Joe
Joe
A moderately priced billet cover TC is around $600 if your worried about cost of just throwing parts at it. Every problem I have seen like you have described has been a TC.
I would find a decent TC to replace with and go from there.
It could be either the VB or TC, hard to tell without tearing it down. It could also be a cracked passage in the case. Those are tough to find.
Missed the place where you said it only does it warm.
Does it do it in all gears like 1st and 2nd if you manually downshift?
You said it runs fine otherwise, does it shift on time or are the shifts drawn out and extra firm?
Has the TV cable been adjusted correctly? Readjusted for any change?
I would expect a transmission shop to check the TV cable first, then possibly suggest changing the governor pressure soleoid and transducer next before getting into hard parts.
Then I would expect them to have a flippin' clue about whats wrong! It doesn't sound like they are the sharpest pencil in the box on these trucks. Might consider finding a shop that has some experience with diesel units and see if they can be any more help.
Where are you located?
