1st Oil Change
1st Oil Change
I just hit 7500 on my '05 3500 and I'm doing my first oil change. My service manual CD hasn't arrived from Daimler Chrylser yet. I'm assuming the big plug with the square drive hole in the middle of the pan is the drain plug. What should I torque it to when I reinstall it? Where is the filter located? Is there more than one oil filter? (I haven't been under the truck yet). Is hand tightened good enough for the filter? Any gotchas I should be aware of? Thanks.
you should put this in your 3rd gen section and yes that is the drain plug and ya aint gotta torque it down, just get it tight. then on the filter, get it good and snug and then just a little bit more
Get one of those oil cap wrenches (i think size C) that fit on the end of your socket wrench extensions. They make loosening your oil filter a breeze. After it is loose, you can spin it off by hand into your zip lock baggie.
I like the Fumotovalve w/nipple for draining the oil. You can get it at Geno's garage for about $25.00 or so and it makes draining the oil so much easier because you can control the flow. The 12 gallons of oil in the pan cames out real fast just taking out the stock plug.
1st Oil Change
jmccart
13
05-27-2009 09:45 PM
doitl8r
06-04-2004 11:14 AM
Blessed
04-07-2004 07:35 AM
RJMontana
12-31-2002 07:48 AM
