19.5 Aluminum rims and G or H rated tires on a 4 x 4 Dually
Who all is running 19.5 inch rims or bigger on their 4 X 4 Dually with G or H rated tires and how's the ride compared to stock ?
I have Goodyear load range "F" on the front and Toyo load range "G" on the rear. Truck rides harsher than stock when all are aired up for towing, if I'm taking a trip not hauling the 5ver I back down on the air and it becomes like stock. The advantage I see with the 19.5's are longevity, they seem to last forever and the side sway.... there is no side sway.
Not a dulley but I've got h rated on a single wheel and the ride is worse but not that bad. Turns much better than it did with the stockers. They are the perfect setup if you are going to haul weight.
I have H rated 22.5's and just air up to support the weight I'm carrying. The ride isn't all that bad. I like a sporty ride anyway.
I usually run F 72psi/R 21psi while unloaded. I usually air the rears up to 30 psi when I load up.........2900 lbs in tongue and cargo weight.
05-29-2009 10:24 PM
buddy26
47
01-04-2007 08:25 PM
sakisaki400
23
12-31-2006 10:17 PM
