180 deg Thermostat For A 2003 Cummins
Old 07-17-2005 | 09:43 AM
  #31
doug60's Avatar
I the winter, my 96 with the stock thermostat would loose 3-4 mpg. If the cylinder temp is to low you will loose efficiently. However I was told by Cummins 180 degrees is optimum. The 12 valve would hang around 160 thats why the mpgs were low. So 180 degree thermostat should be fine, but running at 200 degrees may give us less smoke, better combustion & more mpgs.
Running the 180 could benifit the auto tranny temps witch might be more important. What do you guys think????, doug
cumalong
05-26-2009 06:40 AM
danalex
15
03-07-2009 11:31 PM
doug60
22
08-20-2007 02:21 PM
Buckshotmckee
15
05-20-2006 08:10 AM
HOUTEX
04-21-2005 11:51 AM
Quick Reply: 180 deg Thermostat For A 2003 Cummins
