06 won't start. Dealer can't find what's wrong with it. No codes.
The truck started missing or something while driving down the road then when coming to a stop at a traffic light it stalled and would not start back up. The fuel filter was changed and the diesel looks good. Still not starting. Sprayed carb cleaner in it to try to get it to start and it sounded like it was trying to start but only for a second then stalls.
Towed to the dealer and they ran all their checks and said everything checks out good but it still won't start. What should I look for next?
Thank you for any help.
2006 5.9 cummins 4x4
First take that can of Carb cleaner that you sprayed into your motor and throw it away! Don't use starting fluids. That Carb cleaner trick is only for use on gas engines. Next is it a no crank or crank no start. Big difference between the two and how you go about figuring either out.
Have you tried your spare key yet? My neighbor had the exact start but no run problem with his '06 and it turned out to be the Sentry Key was bad. Used his spare and all was fine. Just something to try.
fuel rail pressure relief valve maybe? It might be able to build enough pressure at the pump but if the fuel rail isnt properly pressurized then the injectors will not open and your truck will not fire. Im guessing at this point...
Enough fuel in the tank, low fuel issues.
Bad battery in key.
Relief valve.
Bad ECM.
Those are the usual issues relative to cranks, fires, quits. There also have been some bad CP3's, cranking pressure seems OK, and all you can do is see the pressure while cranking and assume it's OK, but sustained running pressure is not there.
CD
Bad battery in key.
Relief valve.
Bad ECM.
CD
