06 dodge injectors
06 dodge injectors
i was wondering what would be better, buying new injector nozzles or having your stock nozzles drilled out a little over stock. Also with the 50 or 90 hp injector would they increase your fuel milage any, and if i drill them would the fuel mileage go up or down and how bad, which would you suggest for more smoke and feul mileage
http://www.f1diesel.com/contacts.html
Call one of these guys and see if they can help answer your question. I'd suggest switching out to Formula 1 "Flux" injectors.
A lot has to do with the condition of your stock injector bodies, low miles, no troubles at all, nozzles are a great way to do it. DDP has no core charge and do not need your old nozzles. This helps you out, no down time, do it on the weekend, drive it to work Monday. A lot of the aftermarket nozzles give better mpg via better atomization of the fuel, so long as you can keep your foot out of it.
darrenG
06-21-2005 10:24 PM
