05 wont start after unhooking batteries
Old 05-04-2014 | 11:09 PM
ThatGuy34's Avatar
Exclamation 05 wont start after unhooking batteries
I unhooked my batteries to fix two broken wires at the back door (door lock and rear light). when I hooked the batteries back up the truck acted like the key was in and at the "on" position and then proceeded to try to start itself. no key in the ignition what so ever. truck wont start now. I attempted unhooking and hooking the batteries back up several more times with the same result. Truck is a 2005 2500. I do have a smarty programmed on the truck. help please!
Old 05-05-2014 | 07:57 PM
ThatGuy34's Avatar
Angry
i put new batteries in and still have the same problems. Any ideas what could be causing this?
Old 05-05-2014 | 08:21 PM
dodge2005's Avatar
As a stupid question, have you checked fuses and relays? After the new batteries installed does the truck crank over?
Old 05-05-2014 | 09:16 PM
ThatGuy34's Avatar
i have checked fuses. relays best i can, i switched them around. the truck turns over but wont start. when i hook up the batteries you can hear the fuel pump then approximately 60 seconds later it turns over by itself but doesnt start. no key in ignition.
Old 05-05-2014 | 10:22 PM
dodge2005's Avatar
Wow what a strange problem, having no key in and the truck wants to try to start when you connect the battery. Have you left the batteries unplugged over night?
Have you put the key in and tried to cycle the truck without the batteries connected? This may discharge any capacitors and may reset the truck. After this you could try to reconnect the batteries and see if the truck turns on without the key. Just some thing to try.
Old 05-06-2014 | 01:00 PM
47Dodge's Avatar
Sounds like you have a short and or back feeding something into the truck. I would check your wire repairs for problems or error. Was this something that happened or you bought the truck this way and decided to fix? door lock wire makes me think you could have alarm/auto start and its malfunctioning due to your repair.
47
Old 05-06-2014 | 01:37 PM
ThatGuy34's Avatar
So after changing the batteries and checking all the fuses I continued to have the same sypmtons. When i hooked up the batteries the truck acted as if the ignition was in the on position and after about one minute would crank over. I ended up unhooking the batteries, pulling the ignition on/run fuse, putting the key in the ignition and turning it to the on position, then hooking the batteries back up. The truck behaved the same way except for this time it started when it turned over. So now i have a running truck. truck didnt turn off when the key was cycled to the off position until i touched the brakes. I put the fuse back in and all seems to be normal again. I have no idea *** happened but it seems to be normal now. Thank you to all who tried to help.
SSV1761982
09-04-2013 01:04 PM
mx684
01-01-2007 12:38 PM
edy
20
04-13-2006 03:32 PM
Dusty Ratcliff
05-29-2005 12:51 AM
00turbo
09-03-2004 07:53 AM
