05 Blowby
Old 11-04-2005 | 12:06 PM
Ult680's Avatar
05 Blowby
It seems that my 05 610 has more than average amount of blowby coming out of the blowby tube by the front diff. The front diff. is oil soaked and the tube is discharging a steady stream of bluish smoke. Any thoughts?
Thanks
Jeff
Old 11-04-2005 | 12:35 PM
ramruff's Avatar
Thanks
Jeff
Mine did that when I had a bad injector leaking into the oil. does the blowby smell of diesel ??
Old 11-04-2005 | 03:26 PM
Ult680's Avatar
Yes, and today I noticed I have what appears to be fuel running out of the injection pump as well.
Old 11-04-2005 | 09:07 PM
Ult680's Avatar
I also notice a miss or stuter at times.
Old 11-04-2005 | 09:22 PM
Jonesey's Avatar
It sounds like it is time for you to call for an appointment at your service department. Good luck.
Old 11-06-2005 | 08:51 PM
bigblock2stroke's Avatar
I second that. Although if fuel was getting into your crankcase you should see the oil level rise.
Where is the fuel coming out of the pump at. Got a pic?
Old 11-07-2005 | 07:48 PM
underwoodtransp's Avatar
I agree, Mine cracked an injector last week and it was pushing blue smoke bad. Check your oil level and if it is high I would recommend parking the truck right away untill the problem is fixed. You will smoke the turbo with the thinned out oil.
1ST GEN.
07-06-2005 12:03 AM
I SPEED
12-20-2004 03:17 AM
KATOOM
04-29-2004 12:25 AM
SilverDiesel
10-10-2003 12:55 AM
Evildiesel
10-29-2002 05:22 PM
Quick Reply: 05 Blowby
