04.5 lift pump
Old 02-15-2010 | 08:49 AM
sotex's Avatar
04.5 lift pump
is the lift pump in fuell tank an if so why .on some posts i have red pumps are mounted near fuell filter . seems like out side of tank would be much beter for replacing when bad. and if in tank is that the way to keep it? sotex
Old 02-15-2010 | 09:41 AM
mattk50's Avatar
They were mounted on the fuel filter housing from the factory.They were replaced with the in tank version as a repair when/if the stock one failed.If yours was replaced under warraty or by dealer there will be a sticker under the hood that says somthing like fuel system modified from stock.Mine was replaced at about 63,000 under warranty and replaced with the in tank version.I'm now at approx 165,000 and no problems.
Old 02-15-2010 | 11:01 AM
sotex's Avatar
thanks
i will look for sticker ,i bought this truck 58ooo miles now 98000 . aperes to be in tank becouse i hear it ramping up wile wating for thinigey in dash coil ie heater to go of.sotex
Txwelder
12-18-2023 02:35 PM
Txwelder
05-19-2005 06:10 PM
Yukon Dodge
18
07-01-2004 10:08 AM
Puke
05-22-2003 12:18 AM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
Quick Reply: 04.5 lift pump
