03 info good or bad
Old 02-17-2009 | 05:49 PM
cowboy2526's Avatar
03 info good or bad
I am thinking about getting an 03 I need to know what the pros and cons are about the truck. Its a one ton dually two wheel drive.
Old 02-17-2009 | 05:53 PM
Capp35's Avatar
Is it an HO or SO?
Old 02-17-2009 | 05:55 PM
cowboy2526's Avatar
Im unsure I just looked it up on the internet is there a way I can tell by the vin number?
Old 02-17-2009 | 06:31 PM
Checkmate's Avatar
The vin will have a #6 or letter C in it, but I can't remember which position.
6 equals Standard Output
C equals High Output
I love my 03. Many think they are one of the best years aside from smaller turbo and a few other little things.
Old 02-17-2009 | 06:35 PM
Checkmate's Avatar
Eighth position in the vin number
Old 02-17-2009 | 07:29 PM
cowboy2526's Avatar
what are the few other things. thank you for the help. Its a standard output is that good or bad?
Old 02-17-2009 | 08:41 PM
Checkmate's Avatar
not bad, just not as nice as the HO ;-) ha ha ha
Old 02-17-2009 | 09:17 PM
rich's Avatar
better to add mods to tho,main problem is lift pump
Old 02-17-2009 | 09:20 PM
C Schomer's Avatar
Some were shipped with really low diff lube so check the rear out good. Some had driveline and other vibrations - that should have been warranteed if it ever had them. No problem with a SO, just get a Predator. Check all the AC dampers for proper air direction - defrost, floor, dash, outside/recirc, temp mixing - the 3rd gens are notorious for broken linkeages/dampers. Craig
Old 02-17-2009 | 09:32 PM
cowboy2526's Avatar
Thank you for all the helpful information. It has a 137,000 miles do you think that is to many?
Old 02-17-2009 | 10:00 PM
Checkmate's Avatar
Ha Ha HA. your kidding right ?? Mine had 134,000 when I bought it. It now has 214,000 and I'll still have it past the 300,000 mark.
Old 02-17-2009 | 10:18 PM
cowboy2526's Avatar
Okay thank you I want this to be the last truck I buy for a while so mileage is a small concern.
Old 02-18-2009 | 01:51 PM
SOhappy's Avatar
Great year. If it's an SO that could work in your favor, use it to beat them down on price. $250 in mods and you'll running with the HOs (that didn't sound right, did it?).
Old 02-18-2009 | 01:55 PM
ropnjessi's Avatar
They are known to have drop valve seats, but usually due to excessive EGT's. The 4.5-05's have a better valve seat apparently...
Old 02-18-2009 | 01:56 PM
troll3193's Avatar
my neighbor has one... SWR not a dually... It is bone stock and gets much better mileage than mine...
Bryan
Quick Reply: 03 info good or bad
