03 chasing a issue,
Old 12-22-2013 | 11:21 AM
ratherberacin's Avatar
03 chasing a issue,
03 5.9 auto. 130000km. its allways been a bit hard starting but lately its been worse to the point of not starting at all
it has three codes. map sensor, crank sensor and a boost issue. (codes 113 237 and 336)
it was not preheating at all so I changed the map sensor. pre heats now. but code is still there.
checked battery condition and connections and found ps battery had a broken post. put in a new battery thinking this would fix the issue. didn't.
so now I am thinking possibly the broken/damaged wire by the oil filter issue (looked but saw nothing, going to pull the wrap off and check closer) and swap out the crank sensor.
am I in the right direction or should I be looking elsewhere?. this truck has been babied since new.
Old 12-22-2013 | 08:20 PM
Brad5502's Avatar
Try plugging in the engine block heater and see if it starts about 2 hours later. If so, that's what mine was doing. That told me it might be injectors, so I had them checked and 3 were below 50%. Put in a new set and starts like a champ. There were no other symptoms, towed and ran fine, just wouldn't start.
This occurred on mine around 150K miles and started last winter when the temps got below 40ish.
339K&Counting
02-02-2012 09:03 AM
AggieJustin
13
08-28-2007 11:32 PM
TRCM
12-15-2005 08:46 PM
ddestruel
07-30-2004 08:49 PM
shortround
02-20-2003 05:47 PM
Quick Reply: 03 chasing a issue,
