03/04.5 injector commonalities
Old 09-09-2007 | 05:04 PM
JIMCTD's Avatar
DonM - 03/04.5 injector commonalities
Due to smoke and EGT issues, I'm going back to stock injectors. I have the chance to get my paws on some new 03 injectors, and I also happen to have some new 04.5 tips. I've been told that the only difference between the 04.5 and the 03 OEM sticks is the tips/nozzles, and that if the 04.5 nozzles are transplanted, they'll work fine on the 03 bodies. I called a Bosch shop, Cummins, and a Dodge tech I know tried to research, no joy - no one can answer the question. Anyone here know the answer? Or have a link to a source where I can find it?
Old 09-09-2007 | 05:14 PM
donhov's Avatar
How about asking Don M, I think it is. He repairs and sells injectors so might he have an answer for you, I don't but thought I'd suggest that.
Old 09-09-2007 | 07:37 PM
Bob Wagner's Avatar
spray angle are different.
Old 09-09-2007 | 08:58 PM
JIMCTD's Avatar
Bob -
Spray angle is determined by the nozzle/tip, though, right? Or am I missing an aspect of the injector body that influences this?
Old 09-10-2007 | 01:18 PM
JIMCTD's Avatar
bump
ttt
one more try
(I think that's 10...)
Old 09-10-2007 | 02:05 PM
SSminnow's Avatar
Any chance can you get the injectors side by side for a visual?
Old 09-10-2007 | 03:04 PM
JIMCTD's Avatar
Yep - the bodies measure out identically, including placement of the connector tube ports. Looks like it would work, and the RUMINT I got makes sense - as long as the internals are set up the same. And I'm not brave enough (nor equipped) to crack into the bodies to check that.
Old 09-10-2007 | 03:19 PM
SSminnow's Avatar
It sounds like that the tips are the only thing that is different
Old 09-11-2007 | 10:13 AM
CTD03's Avatar
If this works whats the hp gain going to 04.5 injectors in an 03?
Old 09-11-2007 | 11:01 AM
rich's Avatar
unless its an 04.5 so it wont work the hp has to be the same i believe because the computer cannot tell the differ
Old 09-11-2007 | 12:56 PM
CTD03's Avatar
but what about aftermarket injectors.... i think they might work but whats the gain of the different spray pattern???
Old 09-11-2007 | 02:21 PM
JIMCTD's Avatar
Just to make sure my intent is understood - I'm going to transplant 04.5 tips onto new 03 bodies, and put them in my 04.5 - not an 03.
I do know that the spray pattern issue is the main difference, read that it has to do with the combustion chamber shape, which was modified on the 04.5's from the 03's. I assume this is due to different piston top shaping......
I don't think that you can use 04.5 tips in an 03 - I found posts that said "bad things will happen".......
Old 09-11-2007 | 09:46 PM
PourinDiesel's Avatar
Yeah it will work fine.
Old 09-12-2007 | 08:56 AM
JIMCTD's Avatar
PD - thanks!
Old 09-12-2007 | 10:00 AM
PEAKSTRYDE's Avatar
Great thread!!!!!
It is always fun to read about topics not discussed everyday on here.
Quick Reply: 03/04.5 injector commonalities
