2005 Dodge Ram diesel-I have brakes but no power steering
I have a 2005 Dodge Ram diesel. About a year and a half ago I replaced the power steering pump, brake master cylinder, hydro boost, and steering gear box as I was having issues with the steering and brakes. Everything was working great until today when I was getting ready to leave for a trip. Now I have no power steering, but the brakes work fine. When I put it in neutral and rev the engine up to about 2,000 RPMs I can turn the tires a couple of inches each direction and I hear a loud hissing type of sound.
I don’t think this would be a problem with the power steering pump as the brakes work. Thoughts?
Thanks,
Geremy
Thanks,
Geremy
I know this is an old post but I had the same issue and I went through 3 power steering pumps and 2 steering boxes to figure it out but about 8 months later it started doing it again no power steering unless I get the RPMS up anyone have any idea what's going on? Hydro boost? I read on another forum that there is an orifice on the powers steering pump that can become plugged?
I am really at my wits end with this truck
Seth,
I understand your frustration, I was there. What I found was that the Hydroboot broke inside and left tons of small medal silvers in the line, getting into the power steering pump and gear box. I had to replace all three, and flushed the system several times to get all that stuff out. As I noted above, I had additional problems, that was because I didn't get all of the medal out, it jacked up the power steering pump again. I did addition flushes, replaced the pump and haven't had issues since. To see the medal i stained the fluid through a white rag, then you could see the medal in it. Hopefully this helps.
howe719
07-22-2009 09:18 AM
Mainstmuscle
05-05-2009 11:26 PM
