Wiper Motor
Wiper Motor
Lately has been slow to start wiping. Turn on and can be up to a full minute before it actually starts to do its job. Fortunately here in AZ dont need it much but do need to get it fixed. Have not even started to look to diagnos, just looking for suggestions on where to start. Acts like blades are stuck to window after long time of no use but that is not it. Thanks for the suggestions.
Hi,
I had to replace my motor. Not too bad just remove the top cover and pull the blade arms off and it is then easy to test the motor itself with a short piece of wire from the battery and see if it works right away. If it does then a wiring or switch issue.
THere is a write up on here about repairing this w/o needing a replacement motor. IIRC they are about $160.
Search wiper motor rebuild.
2kayaks
01-25-2014 06:01 PM
