Whining noise - like tires whine but it is not
Whining noise - like mud tires going down the road.
I live on dirt roads and this just started about 1 month ago but it is already louder. Can any one help? Has anyone ran into this?
You can hear this noise starting at 25-30 mph and up. It doesn't vary much with speed though.
I have rotated my tires and I still hear it. Is is the rear end?
I have a 02 Dodge ram diesel.
I am a girly girl so please speak in girl car lauguage-LOL (I don't know anything about cars)
Thanks!!!!
Thanks!!!!
does it only make the noise when accelerating or when you are coasting? Most likly it is either a bearing in your rear end or ringgear and pinnion which is also in the rear end.
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
Does the noise go away when you depress the clutch peddle?
Also, fill your signature with your truck info so we all can see what you're driving.
I watch wind blow...
sounds to me like a carrier and pinion bearing on there way out, (rear end bearings)
my old halfton did this, vibrated the nut loose driving down the road and i lost the drive shaft. OOF. Good luck.
The Noise Only Stops When I Stop Rolling In Or Out Of Gear. No Change In Noise If I Put The Clutch In Either Unless I Stop Or Get Under 20 Miles Per H. I Have An 02 Ram 2500 Deisel. What Do Ya'll Think The Est. Cost On That Would Be And How Long Till It Leaves Me Stranded? Is Is Something That I Need To Fix Asap?
1 Post
Certianly does sound like a rear differential issue. To rebuild a rear end I think you're looking at around $200 to $300 for parts (if just a ring & pinion & bearing kit are needed) and around $300 to $400 for labor. If the ring & pinion are ok and just bearings are needed, labor is the same, but parts will probably only be around $150 to $200.
1 Post
You know......The more I think about it, have you checked the front wheel hubs? The front wheel hubs are a common failure item on these trucks.
Do the "newer" trucks with a Club Cab have the two piece driveshaft like my '96 does? If so, maybe the carrier bearing is on its way out? This assumes that this is a Club (i.e. extended) Cab we're talking about.
John
John
Did the noise move frt to back or vise/versa when you rotated the tires?
Is there any cupping( high and low ) spots on the tires?
If the tires are cupped you will have a noise until they smooth out.
If your on a paved road and your steer left and right kind of rocking the vehicle does the noise change. If so its probably the frt wheel bearings. The extended cab's also have a steady bearing on the drive shaft that could cause the noise but these noise's do sound different from one and other. Living on a dirt road I would suspect the frt wheel bearings but kind of need to know what year your truck is and what model...2 wheel drive or 4x4.
I think some people here are jumping the gun thinking the noise is in the rear end. I really think it's the frt hub and bearing assembly on one side.
Good luck
Good luck
If its a 4X4 do you have any oil left in your transfer case? It doesn't take much to begin with and a small leak can put it dangerously low. If the output shaft is wet its leaking and you wouldn't notice on gravel.
SSV1761982
16
01-28-2019 10:29 AM
sakisaki400
23
12-31-2006 10:17 PM
