Where to get headlight relay harness at?
Old 12-14-2007 | 09:35 PM
rolling18's Avatar
well i just finished installing it and it works!!
so im happy as well as my headlight switch is too hehe
anyway now ill see if i can tap ijnto that relayed harness to power my fogs..
Old 12-15-2007 | 06:16 PM
95black2615's Avatar
Yep, I installed mine about a month ago.
I actually was bright lighted by someone last weekend
Old 12-16-2007 | 10:27 AM
blackimpala's Avatar
Made my own
Bought my truck about three years ago. Built my relay harness and had it in a week after I got the truck. Nice thing about it is you can use any size wire you want, not limited to what "they" want you to use. It has worked flawlessly. I would do it again on any thing I own.
Old 12-16-2007 | 06:49 PM
haloman's Avatar
I am going to try this but use the parking light wire to activate the relay so I dont have any more issues with the highs sticking on with the lows/fogs with the LMC harness.
http://www.classictruckshop.com/club...h/foglites.htm
Old 12-16-2007 | 09:05 PM
Tractor Truck's Avatar
Haloman,
I am looking to get the harness from lmc for my truck. I noticed that you had a problem with your high beams staying on. Is this a common problem for this harness. I have factory fog lights so I am not sure if I will have the same problem. I would like to know if I will have a problem before I order the harness.
Old 12-16-2007 | 11:08 PM
dssimecek's Avatar
Suvlights also has the harness with relays and also can get bright bulbs from them. I have not got mine yet.
Here is a linkhttp://www.suvlights.com/index.php?cPath=59&osCsid=55507398b90da7c171da16be d77f8633
Old 12-17-2007 | 09:04 AM
haloman's Avatar
Originally Posted by Tractor Truck
Haloman,
I think this is a common problem. But with all my other upgrades, I don't use my high beams anymore. I am going to build a harness similar to what I posted above. (have all the parts just no time ATM). That should fix it by using the marker light to trigger the relay and take the fog light load off the headlight switch.
Old 03-30-2008 | 05:08 PM
rolling18's Avatar
well UPDATE!!!
my low beam relay died!!! and i cant find another on the internet!!!
anyone know where to get these?? (besides calling LMC and ordering again)
NONE of the auto part stores even heard or seen them b4..
i dont want to have to mail order relays every time one goes out..
i would advise against this kit due to REPLACEMENT relay availability
Old 03-30-2008 | 05:14 PM
haloman's Avatar
Radioshack should have the relay.
Old 03-30-2008 | 05:27 PM
rolling18's Avatar
thanks for fast responce!! but unfortunatly they dont.
i found the company web page and it was listed there but no info how to order or where to order.. very poor web page
Old 03-30-2008 | 05:33 PM
haloman's Avatar
really? Mine here in town had them. You have the harness from lmctruck.com right? A standard bosch relay should work.
Old 03-30-2008 | 05:36 PM
caper's Avatar
I changed out my relays on the LMC harness to hella relays and bases for easyer replacement. Any one know where ya can find the 2 headlight sockets and the one socket that you plug into the factory harness so one can make their own harness , I can't find them anywhere.
Old 03-30-2008 | 05:38 PM
rolling18's Avatar
yes i have the LMC kit... i cant find bosch relays arround here either..
autozone, schucks/ checker. baxter radio shack ect. auto parts none have bosch
mabey you have a part number??? i will research bosch
the relay that came with it is called "SHORI" has 4 prongs all horizontal in a 2x2 patern female socket...
haloman's Avatar
I found some sockets at walamart, should be able to get them at autozone or similiar.
Old 03-30-2008 | 05:43 PM
haloman's Avatar
Not trying to be smart, have you tried calling some of these place?
http://www.google.com/search?hl=en&s...ectronic+parts
http://www.superpages.com/yellowpage...OR/T-Portland/
