Wheel backspacing problem
Ran into a problem today. I bought some wheels and tires 16" off of a 2001 dodge thinking they would fit my 96. They don't clear in the rear they hit the drum! Is the backspacing different from the 96 to 01? I thought maybe a could get some wheelspacers, but is that a good idea? I was just trying to figure something out because I don't know if the guy will give me my money back. Any ideas would be great. Thanks, John
I've read a little about this problem that people have run into but haven't paid much attention but it seems that a lot of folks have been able to make new rims fit on old rigs with a little bit of grinding. Don't ask me where to grind though, maybe search for rims will answer your question
The newer trucks have different drums which allow the wheels to fit. you may be able to make them fit with some grinding , i have never heard of that before.
You need to remove about an 1/8th from the outer drum lip. I have heard you can have it turned on a brake lathe or grind it. I believe the easiest wat to grind is to put the truck up on stands and put it in gear and let the drum spin while grinding. Grind a little and test fit. Thats what I have heard anyways.. Good luck
Redneck-Express
05-01-2009 12:45 PM
Ramtough
09-02-2005 01:04 AM
Hondo
01-09-2005 09:31 AM
Patrick Campbell
09-28-2003 11:03 AM
tobyw
06-06-2003 01:03 AM
