whch tire LT235/85s or LT265/75s in load range E
I am going to need tires soon I am considering Michelin LTX A/T2’s. I use my truck for recreational use to tow a small fifth wheel and dingy tow either a small trailer behind the fifth wheel with a 4 wheeler in it when hunting or a 17 foot bass boat when I get to go fishing
0r I pull a small cattle trailer with no more than 4 calves a couple times a year or load the bed with a ton of feed every so often. I do not do any long distance towing.
LT235/85s or LT265/75s in load range E have same nominal height, about 31"
And there is only 1 revolution per mile difference traveling down the road (i.e. 656 vs. 657).
other than price is there any reason that should I use one size over the other.
If Your pulling a fifth wheel just be careful that the bigger tires don't mess with how you get under the trailer. it did to me and I had to flip the axles on the trailer which needed to be done anyway.
I believe one size is a little wider than the other.
The wider one will have more sidewall lateral rollout on the stock 8" wide wheel than the narrower one, but probably not much.
I am running 245/75 16E on stock wheels. I think the tire is rated for a 6.5 to 8" rim not sure. Never had a problem towing 5er or hauling the TC. This tire is rated at 3042lbs at 80lbs air the 265 is rated about 400lbs more I believe
LooseBoltsRob
13
09-28-2008 05:06 PM
Firstgenfanatic
04-10-2008 12:24 PM
Mark Hodowanec
03-19-2007 05:55 PM
