Water Pump Leak
Water Pump Leak
I'm starting to get small amounts of fluid leaking out around sides of water pump. I'm assuming gasket must be bad and whole water pump should be replaced. I was just wondering what all is involved in replacing water pump on these trucks, and if it's very difficult?
Is the Gates replacement pump that Geno's sells pretty good that's $35.00. I noticed Dodge wants $295 for their water pump. Do you have to buy the water pump seal separately or does it come with a new one? You don't have to drain the coolant when you do this do you?
Thanks for help or suggestions.
Super easy to replace the water pump, remove the belt and two bolts it's out, you do have to drain most of the coolant to do it, I would get a pump from Cummins, usually way cheaper than dodge, and better quality than aftermarket parts, but I can't speak for waterpumps haven't had to do mine yet
thanks for the information. do you guys have any idea why the fluid leaking out around the water pump would be a brownish color....like it's dirty or corroded.....i use fleetcharge coolant that is a pink color so i don't know why it would be a brown color.....i've checked the coolant level and it is fine.....
i need to use the truck this week just to go back & forth to work so hopefully i'm not hurting anything by driving it until i can change the water pump....it definitely is not overheating or anything....
I got one more dumb question.....Is there anything I could damage by continuing to drive the truck with the water pump leaking.....As long as the pump is functioning the was it's supposed to and the coolant level is good it should be fine? Right? It's probably just going to be a week before I can get to changing it.
I hope for your sake it is the water pump. I had a brownish wetness around my water pump so I changed it, everyone is right they are very easy to change. Mine turned out not to be the water pump it was the front cam housing gasket leaking, a major problem to fix.
2002 Q/C 2500 4x4
2002 Q/C 2500 4x4
ted_pulliam
10-15-2009 08:24 AM
RamWheelsBy4
04-11-2007 04:43 PM
