Water/Moisture In Headlight Assembly
Old 05-17-2004 | 10:21 PM
rattle_rattle's Avatar
Question Water/Moisture In Headlight Assembly
My driver side headlight has moisture in it. Has anyone had this happen and what did you do to fix it? It has blown two bulbs already.
Old 05-17-2004 | 10:34 PM
MnTom's Avatar
Yea, I had the same problem. Only mine was the right side. Get a small drill bit (1/8" or smaller) and drill a hole or two in the front of the housing closest to the grille and drill a hole or two on the side away from where the bulb shines. Give it some time and the moisture will "dissapear". What you did was give the ***'y some air flow. I have not had a problem in over a year with this "repair".
Tom
Old 05-18-2004 | 11:46 AM
Thanks for the tip. I like how the censor took care of that bad word "***'y".
Roperteacher
03-14-2008 11:42 PM
pvcman
01-13-2008 02:22 PM
Roperteacher
09-21-2007 12:07 PM
65fury
06-06-2007 08:44 PM
12valve@heart
05-14-2005 11:54 PM
