washer fluid tank low level indicator light
yanno.... i had this truck for 14 years, last night comming home i hit the washers, stupid dashboard lit up like the whole truck was burnin up.
it was the low washer fluid light. is there a way to tone that thing down some...... i thought the truck was self destructing and the dash was freaking out.
Sorry could not resist. Don't know of a way but now that you know what happens, probably won't be so traumatized next time.
Mines not overly bright.... maybe a retrofit from 2nd Gen CTD.
RJ
It would be a simple matter to disable the warning, just cut the wire at the reservoir.
But then you could run out of fluid and not know it.
Even better system is to check the washer fluid when you check the oil.
EdmontonCanada
11-03-2014 01:59 PM
2006BLKMegacab
11-19-2011 10:12 AM
CamperAndy
01-03-2011 07:17 PM
Larry R
04-24-2006 08:42 AM
