veggie oil
Old 07-10-2010, 07:33 PM
trap grease's Avatar
fuel pick up
Originally Posted by sheriffav8r
Just keep an eye on your fuel filter. Changing a $20 filter for 2 gallons of waste oil can get expensive. I'm just sayin'....
not to mention having to drop the tank to clean the pick up screen. Always filter your wvo before putting it into your truck . trust me its not going to plug with a 1/4 tank i always filter to 5 microns . I would never run wmo in my engine just send it to the hm recycling center .
Old 07-17-2010, 08:06 PM
Vaughn MacKenzie's Avatar
Unless you are set up to preheat the oil I wouldn't run veggie oil. I ran veg oil in my '98 12-valve up to 60-70% in the summer when cut with quite a bit of gasoline to thin it down but even then I found out it was coking my injectors pretty bad. I never ran any veg oil in the cooler or cold months. The deposits on the tips were very hard and took some scraping to remove. I think when it comes to this you can get away with it easier on a 24-valve with the higher injection pressures & better atomization but even then I wouldn't do it without a preheating setup & 2-tank system.
Begle1
07-31-2006 01:03 PM
Begle1
04-25-2006 08:58 PM
Bobcat698
20
10-30-2005 09:40 PM
Tommy93w350
04-19-2005 01:14 AM
robbyd
01-17-2005 07:22 PM
Quick Reply: veggie oil
