turn signals quit after pulling trailer
Pulled a car trailer tonite with no lights cept for brake lights. I went to hit my blinker and nothinh happend. Now even with the trialer off they wont work but the hazards work fine. Any ideas??
It's probably the flasher unit. The stock ones don't hold up when you put a trailer on. It burns up the flasher. Go to the parts store and get a heavy duty flasher and install it. Don't get the cheap one. Tridon fl-tri-12 or fl-tri-13 is the one I always use. one is 2 prong the other is 3 prong.
It had the same probem and It was the flasher unit. If your hazards still work switch uot your hazard flasher for the turn sighal flasher, and if the turn signal works then you found your problem. When you haul it takes its towll on the flashers I got some new heavyduty ones @ Autozone for around 7 bucks.
Try swapping your hazard flasher with your turn signal flasher if they work then your flasher when south
I have one trailer with 4 turn lights per side plus the truck turns it would burn up flashers until I bought a electronic flasher
Stock flashers don't handle extra lights very good
97DodgeSmokin
01-15-2014 07:42 PM
06SLTcs
04-03-2009 11:56 PM
masterphreak
09-25-2007 01:01 AM
