too much rust?
Old 05-04-2010, 12:18 AM
astep577's Avatar
too much rust?
I have been looking around at used 12 valve ctd's and not too many show up. I found a 95 on my way home from college tonight with at, 4x4, 140000. The paint is really nice, a little rust in the door frame that was touched up, but underneath, I was a little surprised.
You can see where a five year old spot shot some black paint in a few places, it makes it look a thousands times better-not haha.
Does this look too rusty? It is a pa truck, but this looks a little bad to me. They are asking 8500, personally, I wouldn't bother unless they come down to $7K but still, would anyone still buy it?
A weekend, plenty of wire wheels, a gallon of por-15, and a six pack would be needed, but is it a little too late to bother with?
Also, one other quick q: those blocks under the rear leaves, is that the stock configuration?
Thanks for the continued help you all provide!
Old 05-04-2010, 08:33 AM
patdaly's Avatar
Better not slide, a 95 with 140K is a premium truck............
8500 isn't a bad price at all for that truck.
Old 05-04-2010, 11:09 AM
Junk Man's Avatar
Put it on a lift then decide. I'd be more worried about rust in the body panels than surface rust on the frame that you can reach & POR. What about other weak places ie suspension & steering. You won't have the VP but there are 12v issues to be dealt with. Read the 12v forums & check those problem areas before deciding.
Old 05-04-2010, 11:52 AM
bludodge21111's Avatar
I agree truck is a good find but you might need more than a 6 pack haha
Old 05-04-2010, 12:19 PM
Robert Rausch's Avatar
I'd get it if I were in the market for one. I like the '95's--my favorite year.
Old 05-04-2010, 07:16 PM
astep577's Avatar
Blue book for it is 7400 suggested retail value. I'm going to test drive it on my way back to school Thursday and talk a little price. Btw, are those blocks under the springs stock? it looks really weird to me...
Also, is there a way to tell if the pump has been played with?
Old 05-04-2010, 07:21 PM
Tacomaman87's Avatar
Those are the same blocks that came on my 01 stock so they are either stock or from a newer truck. the underside of the truck looks good to me. its all just surface rust that can be dealt with the por-15 and beer. check the bottoms of the doors for repairs as well as the dog leg on the frt fender. and over the wheel arches. good luck to you.
Old 05-04-2010, 07:55 PM
atc250r's Avatar
I've been under my 96 for the last two nights doing some work and it looks about the same as that but with only 96,000 on it. Pulling the bed then wire brushing and coating the chassis is on the menu for this spring. I want to get the rust before the rust gets me. I think the worst thing is letting it sit like I do with mine. I'm going to make it a point to drive it at least once or twice a week from now on.
Old 05-05-2010, 12:34 PM
A. Bomb's Avatar
I've seen a lot worse. That looks great compared to my truck. Of course my truck was $3500 also.
Old 05-05-2010, 07:13 PM
astep577's Avatar
ok, i did not know trucks came stock with blocks like that. i checked the doors, they are fine, the repairs look like they are in the door frame. overall, im impressed with the body, it was just the frame rust that threw me off...
Old 05-05-2010, 08:27 PM
diggerphd's Avatar
As 'atc250' suggested, pulling the bed is the easiest way to attack the rust. It's sufficiently a nasty enough job without banging your head. The bed comes off quite easily with the help of a few buddies.
Good luck!
Old 05-05-2010, 08:46 PM
atc250r's Avatar
Had to fix your post digger. LOL!
Originally Posted by diggerphd
The bed comes off quite easily with the help of a few buddies and a few beers.
Much better, right?
John
Old 05-06-2010, 11:37 AM
justme-'s Avatar
yes those blocks are stock for the 4wd models- the ear keeps them from slipping out.
Looks like the underside of mine too.
Old 05-06-2010, 02:40 PM
astep577's Avatar
So I looked at the truck in daylight this morning. Most of the surface rust doesn't look that bad. However, there are three points on the frame where a hole has appeared: one at the front, one mid way along the bed, and another towards the rear end. I popped the hood and the engine bay is pretty clean, she turned right over with no smoke.
The brake lines in the rear also will need to be replaced-they look pretty badly rusted.
The three holes in the frame bother me cause no matter how much por15 and grinding I use, I will never be able to catch all of the rust.
Old 05-07-2010, 09:22 AM
Junk Man's Avatar
I have a 78 Datsun Z with rust in the frame rails. A friend of mine is an old school body man. He sprayed metal prep, then rinsed then the POR into the frame rails. Still going 5 yrs later.
Quick Reply: too much rust?
