Temp readout in overhead console
Hey y'all, my temp readout in the overhead is reading a bit higher these days. It's about 5 degrees to high most of the time. Is there any way to re-calibrate it?
Check these posts see if they help
https://www.dieseltruckresource.com/...threadid=35009
https://www.dieseltruckresource.com/...threadid=36424
There is no way to recalibrate the temp. You can try cleaning the connections to the sensor on the radiator support. If that doesn't get it you'll need a new sensor.
If you are running a winter front the temp will read high.
Can anyone tell me where the sensor is located? and what temp is given? If the sensor is near the Rad.. how is it getting a reading without the heat from the rad?
anyone have any photos what the sensor looks like?
Depends on the year. Some are mounted behind the bumper. On my 01 when you open the hood, look up. Mine is on the latch mechanism, it's the only thing up there . It is more foward than the radiator so it gets somewhat accurate readings. Unless the truck is sitting for a while and gets the radiant heat off the radiator, tranny cooler, intercooler and AC condensor.
pquevill
09-22-2010 05:42 PM
moparmatt
01-07-2008 07:22 AM
mickey5978
08-07-2006 05:47 PM
mitchkim
20
01-16-2005 08:47 PM
Dodgezilla
01-21-2004 11:24 AM
