storing truck on jack stands
Is is acceptable to long term (7 weeks), a 2500 on jack stands under the axles? If not under axles, where? thanks for any advice!!!
Fine.
Remove batteries.
I would change oil first so no contaminates sit in there.
If it's rurally located, keep rodents out of tail pipe and air intake box; mesh or a rag. Whichever method, put a note on the steering wheel so you remember
Remove batteries.
I don't see a problem with it being on axle stands for less than 2 months, or even longer for that matter. Maybe top up the fuel tank. Plus what the others have said.
Cheers!
Mike
Cheers!
Mike
My uncle sits his 57 t-bird on jack stands from around the beginning of September to sometime in early spring(Western N.Y) and has done that for as long as I can remember(I'm pushing 40) and never heard, seen any ill affects.
7 weeks isn't a very long time to let it sit on tires.
A wad of steel wool will keep things out of the tailpipe and airbox better than a rag. Rodents won't chew it.
