Spacers between vacuum pump and steering pump?
Truck is a '95 12 valve 2 wheel drive. Power steering pump finally went bad. Took it apart and thought I'd replace the vacuum pump seal that has been weeping for years - I've been dreading this job but it was no big deal so far.
No local auto parts has the ps pump so I thought I'd go ahead and order it from Geno's and the vacuum pump reseal kit along with it.
Anyway, my confusion and question have to do with the fact that there was exactly one spacer between the vac pump and ps pump, where the factory manual shows two and claims in writing there are two. It is a matter of the shape of the ps pump, three of the mating faces to the vac pump are at the same height (same plane), one is recessed a little and needs the spacer to bring it up to the same level.
Does it seem like I have an oddball pump/setup, or am I just being silly and trusting the manual too much? Don't want to order the new pump and have it not fit.
It is Sunday night, I've arranged a ride to work tomorrow, will see how the week goes - but I'm not going to sleep very well, I really want to call Geno's and ask them about this, and order the parts if they think they are right. This is only the third time in 18 years the truck has been "down" - and one of those was over Christmas break / plant shutdown, so getting to work was not an issue (had the dash out to replace heater core/ac evap).
Sorry to babble, thanks in advance for any guidance y'all can send my way.
Regards,
Andrew
Regards,
Andrew
Regards,
Andrew
Regards,
Andrew
97 on parts book makes no mention of a spacer, though I swear mine had one........
Thanks patdaly!
Want a good laugh? I got a good look when I went to take out the mounting studs, and there really are two spacers. One (on a stud) was so stuck that it seemed to me to be part of the pump.
So my confusion was a direct consequence of my failure to look closely, finish taking apart / cleaning, and being so emotional about my truck.
Stepping back and looking at this, there is nothing to get worked up about. I got a rebuilt pump at the auto parts, ordered the vacuum pump seal kit from Geno's, and will take a vacation day at work once I've got all the parts and ducks in a row.
Thanks again for your help and for taking the time to read and respond.
Regards,
Andrew
Regards,
Andrew
Closing the loop
Seal kit came from Geno's Garage, got a rebuilt ps pump from autoparts, all went together just like it should, steering works, no leaks (will keep looking).
All in all it was not a big deal.
I was unwise to put off fixing the leaking seal at the vacuum pump until I *had* to take it all apart to replace the ps pump. The slow leak for years made a mess and the pump assembly was just not that difficult to get out, replace the seal, and reassemble.
Anyway thanks. Knowing that y'all were here to ask, if I got in over my head, was a comfort.
Regards,
Andrew
Over 536 k miles now.
Regards,
Andrew
jimbo486
05-08-2016 06:07 PM
dzl_damon
03-19-2010 05:17 PM
Rollin' Smoke
10-10-2007 08:14 AM
SmokinFive9 4x4
12-03-2005 06:38 PM
