Simple A/C Fixes
DTR's Cow Boss
Simple A/C Fixes
when i bought my truck three years ago it had no too little a/c oh well is what i thought then came summer so i brought it in the shop and had the system checked out and found that the valve core on the low pressure side took a dirt nap and they replaced the core and charged the system GREAT cold A/C again. Fast forward two winters and again this summer no A/C again . Lesson learned from previous years I checked an low and be hold my high pressure side had came loose and i could see were the freon had came out and went over tightened it back down and bought the little recharge kit at napa filled her up got the pressures 25-45ish and blowing cold cold colddddddddddd air again I ran out of the juice id like to get the pressures touching the high side of 25 and the top side of 45 but untill tomarow when I can get too town for one more shot of 134 cause i know it can be colder.
Lesson learned here guys is if your having A/C problems but every thing else seems to be working check those cores its simple and easy and it will save you a 80 dollar dr visit just for them to put a one dollar core and 30 bucks worth of 134 in.
DTR's Cow Boss
I dont know what hte high side is cause i dont have a deal too test it but i went back to town any ways had to get food and picked up another can because when i checked my low side once it all cycled it was at 18psi so i ramped it up to 35psi and its ice cold again hurrray wish i would have not put this off so long i thought it was my compressor no way could another stinking core de rail me
I was reading in my service manual and it gives what the press. should be with the different ambient temps. I think it said if the temps were @95 the low press. should be in the 50-60 range. It also said that if it was cooling at 35-40 leave it there. Kind of contradictory of everything I've been told so I just charged it to 40 and left it alone.
TXTad
03-09-2007 09:11 AM
bkrukow
39
04-23-2004 04:52 AM
hellotbone
16
03-31-2003 08:28 PM
