Rust repair? is it worth it?
I have some cancer spots showing up on the bottoms of my doors, and around some of the wheel wells.
It is just bubbles, and some small rusty spots.
I would like to know how successfull people have been with re-paints. if you sand all the rust away and repaint dose it just come back in two years?
How long did your rust repair last??
Thanks,
Thanks,
Thanks,
Thanks,
General rule of thumb is that you want to go 1/2" past where you see the rust stops.
Rust can be repaired permanently if you use the right stuff. I've used POR15 in the past. Seems to work ok, but it's a PITB to work with, and It's now #3 on my list of rust cures.
#2 on the list is Eastwood's Rust Encapsulator. The big pro for this stuff is that you can get it in aerosol. That said, it's not very tough and needs a really tough top coat (the POR is tougher, imo-- but needs a topcoat because it's UV sensitive.).
#1 on the list is a relatively new product called Rust Bullet. It's simply the best available, imo. It prevents rust the best of anything I've seen. Check out their website at www.rustbullet.com-- and look at the tests they had an independent lab do of RB against almost all the other players on the market. See for yourself. It's also much easier to use than POR15 imo, in addition to working better.
Repairing rust is worthwhile IF you do it right- it will come back otherwise.
jmo
Looks like I will have to wait until the end of the month. The new product, Black Shell, will be available July 30. Perfect for my black ram.
It says you just scrape off the flakes and apply 2 coats... Sound like a bit of a fairy tail..
Anyone had any long term experience with this?
pete97
10-27-2007 03:28 PM
